Re: IH WD-9 Compression Lever
Posted by rustred on February 28, 2012 at 13:58:46 from (74.200.18.156):
In Reply to: Re: IH WD-9 Compression Lever posted by sflem849 on February 28, 2012 at 11:10:30:
yes you need the manual, as the friction control needs a pull of 75 lbs.tension for the adjustment. if you got it oily then this may be your problem .it is quite an intensive adjustment for the whole set up. once warmed up on gas. the compression release lever is to be pulled first.this switches it to diesel mode. then you give it some throttle. i dont know where this automatic stuff is from.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
