Super A Wheel Weight (Again)
Posted by Stan on September 13, 2000 at 17:19:12 from (12.87.65.209):
Apparently I didn't phrase what I was looking for properly in my earlier post. What I was looking for was the weight of the drivers side rear wheel that I will be taking off to do some brake work. Not the weight of the bolt on wheel weights.
Having said that thank you anyway for the info on wheel weights.
Any idea on the weight of the wheel without the wheel weights. If the hub is supposed to be a counter weight for the offset motor I'm thinking it might be awful heavy.
Post A Followup
: Re: Super A Wheel Weight (Again)
