Re: H wheel width
Posted by The Dukester on February 28, 2012 at 15:32:29 from (4.229.144.69):
In Reply to: Re: H wheel width posted by Pete76NY on February 28, 2012 at 00:05:44:
How did you get a Super H with gears that make it faster in 5th gear than a regular H? 5th gear is a "straight through" 1 to 1 ratio in the tranny. Your Super H may be revving up a little higher than the 1815 max. no load idle speed. If you put W-4 final drive gears in the rear end it'll make all the speeds faster, that's the only way I ever heard of to make 5th gear faster.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
