Re: Farmall A seals, bearings, and gaskets
Posted by JRSutton on February 29, 2012 at 05:08:13 from (75.130.109.233):
In Reply to: Farmall A seals, bearings, and gaskets posted by ADLM on February 28, 2012 at 18:01:16:
Not to talk you out of changing all of your seals, but if it's leaking that badly, I can almost guarantee you that your transmission is overfilled (or has lots of water in it).
There's only supposed to be about 5 quards of tnas oil in there.
I know I had the same leaking problem on mine, drained it to put fresh stuff in and what came out filled a 5 gallon bucket. (this was right after I bought it)
After I replaced the correct amount - no more drips.
If you're ripping it apart anyways, by all means do the job right and replace them all. But if you find your wobble problem ISN'T bearing related as somebody else here suggested, you may find you can hold off on doing the seals too.
