Posted by dej(Jed) on February 29, 2012 at 07:05:47 from (141.189.113.1):
In Reply to: Seized or not posted by Andrew Z on February 27, 2012 at 17:59:27:
Rule of thumb:Before you do anything, remove the oil drain plug and catch some in a qt. jar. (Not the pit cock valves, the drain plug). Let it stand and observe. If you have no water, you should be able to free it up without dumping a fortune into it. If you have green water on the bottom the block is cracked or the head gasket is blown. Clear water is rain water that came in through the stack. This can be bad, but usually will mean only one cylinder is stuck. I have freed up several tractors and I find that an oak block and a 10 lb sledge works the best.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
