Posted by screwstick on February 29, 2012 at 09:24:59 from (174.24.8.24):
In Reply to: Cub tie rod adjustment posted by Travis Troxell on February 29, 2012 at 08:56:49:
The clamp is only for extending the rod out to match the extension of the axle. Tighten the clamp back up in the same notch that the axle is set to.
To adjust the tie rod, the socket at the end where it attaches to the spindle arm is threaded with a jam nut. Loosen the jam nut, and turn the socket in to the desired toe in. Adjust the socket to where you have the front of the tire 1/4" closer than the rear of the tire. The screw at the end of the socket should be tight enough to limit the play to a minimum with a cotter pin installed to keep it in place. There is no adjustment at the ball socket end except for shims to reduce play.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
