Your pump is gonna need between about 11 - 13 HP when working at capacity.
That's a LOT for a belt-driven pump. It will require 2 - 3 belts to work reliably - and probably 4 belts if you want it to work when the belts get dusty, wet, etc.
You will find direct drive from the front of the crankshaft much more satisfactory. My Oliver 1600 industrial is set up this way and it works great. (Only problem is you gotta disconnect the pump to change the fan belts.)
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
