Re: 3 point hitch conversion for farmall M
Posted by Farmallguy SEIA on February 29, 2012 at 16:06:52 from (173.27.1.27):
In Reply to: 3 point hitch conversion for farmall M posted by AngusCattle on February 29, 2012 at 15:38:04:
These hitches use one or two standard cylinders. If your tractor has two way hydraulics you can have down pressure. Depending on your tractor you can plum them into your belly pump or if you have live hydraulics's you can use the pump on the engine.
