Re: Farmall A seals, bearings, and gaskets
Posted by gene bender on February 29, 2012 at 16:55:57 from (67.55.226.114):
In Reply to: Re: Farmall A seals, bearings, and gaskets posted by ADLM on February 29, 2012 at 13:42:30:
If you take off the cap on the inside of the final drive you mite find out the nut is loose allowing the axle to move in and out what kind of noise does it make when driving around in 2nd gear slow. If the bearing on the axle is bad the gear would make some loud noise
