Re: How to install a cylinder sleeve in an original RC 450
Posted by Fritz Maurer on February 29, 2012 at 17:36:29 from (216.137.136.168):
In Reply to: How to install a cylinder sleeve in an original RC 450 posted by earl in pa on February 29, 2012 at 11:40:21:
It's possible it went down too far. Of course, check the head and the gasket, but check the liner protrusion before you put the head back on. I don't know what an 'RC' is, but generally you should have zero protrusion with a wet sleeve ( only the step in the liner should be above the block) or .005" protrusion with a dry sleeve. In no circumstance that I'm aware of, should the liner sit below the surface of the block. If too low, the only way to fix it is remove the liner and put shims under it, at the counterbore.
