Posted by Bob M on February 29, 2012 at 18:57:07 from (69.207.87.61):
In Reply to: farmall m governor posted by jdetig1 on February 29, 2012 at 16:12:10:
Before you start swapping springs, rebuilding the governor, etc. check the governor to carb throttle shaft linkage is properly adjusted (adjustment is on the bellcrank beneath the sloped cover atop the riser on the gov housing.)
Also if you decide to swap governor springs, a stiffer spring will "wake up" a sluggish governor. But it will also make it more likely to hunt/surge.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
