Re: How to install a cylinder sleeve in an original RC 450
Posted by Janicholson on February 29, 2012 at 20:30:52 from (67.72.98.45):
In Reply to: How to install a cylinder sleeve in an original RC 450 posted by earl in pa on February 29, 2012 at 11:40:21:
The dry sleeve should not be below the deck, .003 to .005 will be fine. If it were mine, I would pull the pan and look to see where the coolant is leaking from. Put 7 psi (no more) in the radiator, and use a good light to find the source. If it leaks between the cylinder sleeve, and the block casting. it likely has a crack in the cast bore. (not a disaster if repaired)
Usual best practice is to bore out the block for a pretty thick repair sleeve, then bore that for the correct dry sleeve (and the top groove for the dry sleeve rim can be machined to exact protrusion) Jim
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
