Re: Head (bolt) studs
Posted by Farmall450man on February 29, 2012 at 23:53:26 from (206.222.178.179):
In Reply to: Head (bolt) studs posted by SMTA on February 28, 2012 at 11:58:09:
You might try double nutting the top of the stud, tightening the nuts really good and then tack weld them together. Then use a 1/2 inch impact gun. If that doesn't break it loose you can take a hack saw to the tack weld and take the nuts back off. Don't use your head nuts for this, as they're not the local hardware kind. It always amazes me what an impact gun will get loose after I've busted my knuckles with breaker bars.
