Re: 3 point hitch conversion for farmall M
Posted by glennster on March 01, 2012 at 03:32:37 from (99.90.9.153):
In Reply to: Re: 3 point hitch conversion for farmall M posted by glennster on March 01, 2012 at 03:15:12:
in the third picture you can see the hydraulic control rods. if you look at the belly pump control rod (with the loop handle) i welded a short piece of a bolt down the rod a ways. that will hold the pump control in the full on position for using the two way hydraulics. the rod above it, with the little pipe handle, controls the two way valve. the big red knob below the belly pump control is for the m+w 9 speed transmission control. i have a pioneer coupling on the left side of the tractor at the belly pump output, so i can disconnect the two way valve and hook up the one way hose for using the one way cyliner on the barge box wagons. the saginaw is a very nice hitch, and well made. i picked my hitch up from the guys that build them up in michigan, real nice fellows.
