Use small rubber balls to plug the inlet and outlet. fill the radiator. Put a pressure cap on it (7.5psi) use a hand air pump tp put pressure in it (a small tube through the ball would do, or a fitting and shrader (tire valve)in the drain threads). Pumping will prerssurize it. Take pictures of the apparatus and (if you want to get carried away, put a pressure gauge in the line) Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
