Re: McCormick W6 / Super W6 seat.
Posted by rustyfarmall on March 01, 2012 at 07:27:55 from (216.248.71.224):
In Reply to: McCormick W6 / Super W6 seat. posted by NY 986 on February 29, 2012 at 21:07:06:
Careful use of a die grinder with a cut-off wheel will cut through those welds. You probably will need to replace the hinge pins, and maybe even do some repairs to the holes the pins go through, but with enough patience, I think you can save it.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
