Re: 3 point hitch conversion for farmall M
Posted by Ellis Kinney on March 01, 2012 at 07:29:18 from (74.130.194.205):
In Reply to: 3 point hitch conversion for farmall M posted by AngusCattle on February 29, 2012 at 15:38:04:
AngusCattle: I recently installed a Saganaw on my 1944 M. It is really fairly simple. Once the hitch is bolted up, which will take you 3 or 4 hours, Run one hydraulic line to the back of your tractor. Install a tee and send one line to each of the cylinders. It is best to use hydraulic fittings instead of pipe fittings due to pressure issues, but pipe fittings will work. The small bales you refer to will be no problem. That is exactly what I do. Ellis
