Re: Parts Washer
Posted by Senator on March 01, 2012 at 15:06:20 from (72.37.249.92):
In Reply to: Parts Washer posted by Super-H-Mike on March 01, 2012 at 08:12:36:
I've used Kerosene for quite a few years with no problems. Flash point of Diesel is around 140 deg and Kerosene is around 100 deg. Flash point is the temp where it produces enough vapor to ignite.
So unless your parts washer gets above 100 deg Kerosene should be safe enough.
Used to use Stoddards, great solvent but the cost is too high anymore.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
