As you know, the generator F terminal connects to the light switch, which grounds the field through the switch box cover, switch box, steering pedistal, tractor frame, then back to the generator case.
If any one of those half dozen spots where parts screw or bolt together has rust that prevents a good ground between the light switch case and generator case, the gen field will not be grounded and the generator will not charge.
If you run a new ground wire from the light switch body to the generator case, bypassing all those rusty joints, I bet your charging problem will go away permently.
As a test, temporarily connect a wire from the generator case to the light switch case and see if your generator comes to life.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
