Re: What's this H worth?
Posted by davediehl@hotmail.com on March 02, 2012 at 04:45:58 from (184.18.118.107):
In Reply to: What's this H worth? posted by CorpRanch on March 01, 2012 at 22:24:43:
If the tires are good, I would say between 5 and 800 if its complete less sheet metal. I would be hesitant to be over that.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
