Re: Farmall Super H Water Temp Gauge
Posted by GordoSD on March 02, 2012 at 06:33:34 from (216.106.252.74):
In Reply to: Farmall Super H Water Temp Gauge posted by Global Warmer on February 29, 2012 at 16:07:47:
Welcome to the forums. I can see from your post that you have fairly limited mechanical knowledge and skills. So this is a good place for you to imnprove them.
I would suugest two things that will help you along. One, do some reading both on the net and in tractor manuals. Get an owners manual for your SH off Ebay.
The other is perhaps on your next project post questions BEFORE you start.
When you replace the temp sensor, have the correct size bolt for a plug, while you install tape on the sensor. Then top off the radiator with 50-50- anti freeze/water. Be sure and leave the level a couple inches below the filler neck for expansion. Good Luck.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
