Re: Gasket Sealer
Posted by CNKS on March 03, 2012 at 07:22:49 from (216.144.104.128):
In Reply to: Gasket Sealer posted by Jim Paterson on March 03, 2012 at 05:45:33:
Copper coat on all gaskets. You might consider Permatex, etc if the surface is deeply pitted. As Jim said on the oil pan and valve cover only do the top side if any at all. You will have to remove the valve cover to readjust the valves. Oil pan is more likely to leak from bent medal as opposed to the gasket.
