Re: Gasket Sealer
Posted by Senator on March 03, 2012 at 08:34:51 from (75.94.36.133):
In Reply to: Gasket Sealer posted by Jim Paterson on March 03, 2012 at 05:45:33:
I always use a very thin film of RTV on most gaskets (not head gaskets or carb gaskets). Also a bit of RTV on any water (radiator) hose connections. Helps them slide on easier and prevents any small leaks.
