Re: Farmall M Hydraulics Pro's
Posted by rustyfarmall on March 03, 2012 at 09:03:23 from (216.248.71.224):
In Reply to: Farmall M Hydraulics Pro's posted by Mike1972chev on March 03, 2012 at 08:47:01:
Sparky7018 said: (quoted from post at 09:47:01 03/03/12) I have a three point on my M with a M&W valve off the belly pump. If I install a trip bucket front loader would the belly pump run it also? No need to run the 3 pt and the front loader at the same time. Appears to me it would handle it. I suppose live hydraulics is the answer, but I am not sure what all that would entail and if the belly tank is large enough to handle it. Thanks, would appreciate recommendations.
Easiest solution would be too replace the M&W valve with a newer, 2 spool valve. 1 spool to run the loader, the other spool to run the 3 point.
[img]third party image[/img]
This post was edited by rustyfarmall at 11:40:46 03/03/12.
