Re: Are 6 volt batteries always positively grounded?
Posted by AG in IN on March 03, 2012 at 09:58:24 from (67.236.108.207):
In Reply to: Are 6 volt batteries always positively grounded? posted by Hoopa on March 02, 2012 at 23:27:37:
Like others have said, the spark plugs can care less about voltage or polarity of your battery.
With battery ignition, the the wires into and out of the coil do matter with a change in polarity. IIRC, it's in on the hot, out to the distributor on the ground. Otherwise the spark will be weak and the ignition contacts can bridge instead of pit.
I was also told that years ago voltage regulators were polarity sensitive and the material the contacts used differed from positive to negative ground regulators. The old 6V regulators I've taken off have been stamped "6V pos. grd." or something similar.
AG
This post was edited by AG in IN at 10:06:51 03/03/12 4 times.
