Re: Farmall Cub problem
Posted by El Toro on March 04, 2012 at 06:16:13 from (108.3.225.57):
In Reply to: Farmall Cub problem posted by gtwist on March 03, 2012 at 19:23:33:
When it quits running check for fire to your plugs asap before the engine cools. If you still have good fire to your plugs. Remove that tube fitting where your gas line connects at the carburetor. Look for a screen behind that tube fitting that may be plugged with dirt or rust. Hal
