Re: H streering
Posted by John Missouri on March 04, 2012 at 08:42:38 from (69.150.232.90):
In Reply to: H streering posted by Steve Lambert on March 03, 2012 at 14:28:43:
It is super easy. Just get a large pipewrench and unscrew the big nut at the top of the bolster.
Disconnect the steering shaft coupling, that is located near or above the valve cover. Do whatever you need to get it disconnected, they can be pretty stuck.
Last, twist the steering shaft and it will "worm" itself away from the steering sector gear, twist in a direction that makes it move towards the front of the tractor, then you just pull it the rest of the way out.
