Re: 856 starter
Posted by Owen Aaland on March 04, 2012 at 10:10:45 from (216.47.33.245):
In Reply to: 856 starter posted by bob7337 on March 04, 2012 at 07:59:16:
It will bolt right in the clutch housing but the gear will be too small to engage the flywheel teeth.
If you were to replace the smaller gas starter gear with the one used for the diesel the starter would not be able to crank the engine very fast and the diesel needs cranking speed to develop enough heat to ignite the fuel spray.
