Re: m block drain
Posted by Owen Aaland on March 04, 2012 at 10:20:18 from (216.47.33.245):
In Reply to: m block drain posted by Old-F20 on March 02, 2012 at 16:45:00:
Yup. Both the block drain plug and the radiator drain cap were designed to be able to use the hand crank to remove them.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
