Re: One More M Hydraulic Pro Question
Posted by rustred on March 04, 2012 at 11:20:14 from (74.200.18.156):
In Reply to: Re: One More M Hydraulic Pro Question posted by Sparky7018 on March 04, 2012 at 09:40:18:
you should be ok, those tractors picked the 10' cultivator and 3 btm plows out of the ground so it should split a log. those old j.d. cyl's were only rated for low pressure though. if hooked to a newer tractor you would blow them apart litterly. you could increase the cyl.bore size if you needed more pushing power.
