Re: Will a 560 fast hitch fit an M?
Posted by Bill Lisbon on March 04, 2012 at 12:24:47 from (69.89.163.146):
In Reply to: Will a 560 fast hitch fit an M? posted by BigTone on March 04, 2012 at 12:15:08:
If what you are looking at is a factory 560 fast hitch, it will not fit a M, The M rear end is not drilled and tapped for the mounting of the hitch.
