It is possible to get the seals out without complete disassembly, but,it may require some ingenuity. First is a dust seal that is easy to get out. Then there is a snap ring. The next piece is a spacer with a needle bearing in it , o-ring on the inside that seals on shaft and o-ring on outside that seal on housing. Problem is to get a hold of that spacer. If it has a shallow hole drilled and tapped you can pull it out with a bolt or slide hammer. If it does not have any holes, well, that is the iffy part. I have had several apart but normally for other reason so take them all the way apart. That can be a problem also as the spool inside is a very close fit to housing and spool stays with the shaft so careful does it. The CaseIH online parts manual shows a breakdown of the unit as used on a 400 tractor for instance.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
