Re: Straight pipe or muffler, not your normal reason for ...
Posted by ericlb on March 05, 2012 at 06:43:56 from (70.41.96.39):
In Reply to: Straight pipe or muffler, not your normal reason for asking posted by mkirsch on March 05, 2012 at 05:51:40:
id check the muffler for internal colaps, but if thats the problem the tractor should sound noticable different, how does it overheat? is it showing hot on the gauge or is it blowing water out the radiator overflow? if its showing hot on the gauge, if it were me id try installing a new gauge right on the engine and see if the sending unit on the engine is lying to you, establish if the engine is really running hot or if its showing hot but running normally, if its blowing water something is definatly wrong , and fruther investigation is needed
