Re: H or Super H?
Posted by mkirsch on March 05, 2012 at 13:55:06 from (64.80.110.74):
In Reply to: H or Super H? posted by Global Warmer on March 05, 2012 at 09:22:19:
Gordo, not so.
Super H's below serial 19234 should have no extra holes in the grill, no holes for pins in the front bolster, and a 2-bolt starter.
With such a low serial number, the tractor should have disk brakes if it is a Super H.
Disk brakes are identified by a heavy cast-steel drum held on by 5 bolts.
