On this first one for a 650, I just drew a high contrast shape with a felt pen and let a metal fabricator use his "seeing-eye" pantagraph, torch out the 3/4" metal pieces. This was done about 15 years ago.
On the second one, I made templates from sheet plastic and mailed them to a shop that does nothing but burning. In both cases, the holes are located in the plate one at a time. I use a threaded fastener with a point machined on the outside end. It goes into the tractor frame and protrudes about 1/16". The plate gets whacked against it.
All this cutting can be done with high precision with a water-jet or laser. All the fabricator needs is a good print. The cutting head is controlled with a digital file. Those with cad-cam software could probably send the file on an email.
Here are a couple more pieces professionally torch-cut. I like square cut kerfs. Some might think that the hardware was factory made.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
