A straight pipe if ok if you have a cab on a 1066. You are not going to tell a difference with a straight pipe on your engine temp, not enough to notice. Was your radiator boiled out at a radiator shop or did you flush it out your self? If it runs hot only under a heavy load it also could be a timing problem. Some machnics advances the timing up to 22 degrees and fuel up on the pump and that will cause higher engine temps but you will have a increase in power. A heavy duty radiator off a 1086 thru 1586 and changing the fan from a 6 blade fan to a 8 blade fan might help also. I did that on my 1466 a few years back and that did help a lot because it was turned up to about 180 hp an running pretty warm pulling a 20 ft disc in high 1st gear.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
