Re: 450 diese lgas side
Posted by d282 on March 05, 2012 at 17:32:18 from (166.182.3.221):
In Reply to: 450 diese lgas side posted by WayneIA on March 05, 2012 at 12:05:09:
Check your butterfly adjustment inside the intake manifold. I worked on a 650 earlier this year with the same symptoms. The switch-over linkage was not closing the intake butterflys all the way. It is a lever the fits into a V. You can look up behind the manifold and see, or pull the manifold off and make sure they are both closing at the same time.
