Re: Iron weights vs rim guard on M
Posted by Mike1972chev on March 06, 2012 at 03:38:37 from (75.149.81.173):
In Reply to: Iron weights vs rim guard on M posted by Stumpy(NH) on March 05, 2012 at 16:27:46:
I vote wheel weights over adding fluid for MANY reasons.
#1You can drop weight quicker.
#2 tire repair with ANY kind of fluid inside is nasty
#3 If you drive down the road on 5th gear,partially filled fluid tires can do some "weird" stuff while trying to stop quickly.
#4 Taking FULLY loaded tires off the tractor can be FATAL if you drop one on yourself!!!!
