Re: Restoring an IH Farmall 140.....UMBRELLA IDEAS??
Posted by Hendrik on March 06, 2012 at 14:29:25 from (194.53.253.51):
In Reply to: Restoring an IH Farmall 140.....UMBRELLA IDEAS?? posted by rtr on March 06, 2012 at 07:38:56:
On the top of the transmission case, close to where the PTO assembly bolts to the transmission, there are two threaded holes, possibly still with the factory cork in them. (The holes are vertical and the line conneting the two holes is parallel to the rear axle.)
I remember that our late friend Hugh Mackay used these holes for mounting an umbrella.
HTH, Hendrik
