Re: H hydraulics
Posted by Janicholson on March 06, 2012 at 17:10:05 from (67.72.98.45):
In Reply to: H hydraulics posted by ND856 on March 05, 2012 at 21:02:10:
I do not think they will work. The gears are also
different. The tractor needs to be older than mid
1950 to allow the pump to bolt up, and it is best
practices to change the gears to late model to avoid
cam gear breakage. Jim
