Re: Ring and Pinion backlash on Farmall M
Posted by rustred on March 07, 2012 at 09:43:40 from (74.200.18.156):
In Reply to: Ring and Pinion backlash on Farmall M posted by schultz on March 07, 2012 at 08:31:12:
it should be in the .008-.012 range. .040 is way tooo much. its not just backlash , but you must get the crown and pinion tooth contact correct also. to do this you need prusion blue or the yellow stuff to check the pattern.if you found the backlash in the book then follow the book for setup.
