Posted by pete 23 on March 07, 2012 at 10:11:02 from (74.32.238.142):
In Reply to: Power Steering posted by Tinks Pulling on March 06, 2012 at 13:38:48:
If it works when activating one of the other levers that shows that the flow divider valve is leaking. The spool comes out under that cap with a snap ring on left side of regulator, flow divider valve assembly. You may get lucky,( I have several times) and just need a new spool which was available just a couple years ago. The edges of the spool erode and then leak past. If the bore is worn too much then a new spool won't help. The valves can be rebuilt but it is very expensive.
