Posted by LJD on March 07, 2012 at 12:23:58 from (75.250.173.12):
In Reply to: Glow Plug System posted by Alan Reynolds on March 07, 2012 at 05:44:14:
There's a new tech glow plug available for your engine now. Dual-coil, 12 volt fast-heat and eliminates the need for that indicator/resistor. I put them in two of my British IHs and they work nicely. Heat in 10 seconds instead of 60 - and burn-out proof.
The original plugs are wired in series and operate at less then one volt each. The new Bosch plugs run on 12 volts and get wired in parallel.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
