Re: H axle bearing
Posted by rustyfarmall on March 07, 2012 at 13:12:24 from (216.248.71.224):
In Reply to: H axle bearing posted by pete 23 on March 07, 2012 at 13:01:37:
That price probably is not too far off. Bearings and oil seals are priced according to the popularity of the application. The fewer the applications, the higher the price. The cost for setting up to produce a bearing is the same whether it is a run of several thousand pieces or just 100.
Shop around a bit. You might be able to knock $20 or $30 off the price, but if you find one priced considerably below that, question the quality.
I wouldn't be afraid of a NICE used bearing either.
