Posted by Zachary Hoyt on March 07, 2012 at 13:27:35 from (184.10.239.246):
In Reply to: H axle bearing posted by pgarrett on March 07, 2012 at 13:01:37:
I have 12 axle assemblies from Hs I have parted out. I have taken one apart to weigh the parts to see if they would be mailable and I also found that the bearings seemed to be good and tight. I'd be happy to sell a bearing for $10 plus postage if a used bearing is a possibility for you. I know I can ship for $6 in a flat rate envelope, might be cheaper another way depending where you are located. Zach
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
