Re: Which replacement factory style coil to buy? 6 or 12 Vol
Posted by mkirsch on March 08, 2012 at 05:31:22 from (64.80.110.75):
In Reply to: Which replacement factory style coil to buy? 6 or 12 Volt?? posted by Mike1972chev on March 08, 2012 at 05:11:07:
Does the tractor have a ballast resistor in wire running from the ignition switch to the coil?
If yes, then 6V.
If no, then 12V, but MAKE SURE the "12V" coil you purchase says "no external ballast resistor required."
Most 12V coils are really just 6V coils, and need a ballast resistor. The reason for this is to prevent confusion at the parts counter...
"I need a coil for my 1969 Dodge Charger."
"Here is a coil."
"But, it's labeled 6V. My car is a 12V."
"Yes sir, that is because there is a ballast resistor on the firewall. All coils are 6V."
"But, my car is 12v. I need a 12V coil."
"Sir, trust me, it will work fine."
"But, my car is 12V. I must have a 12V coil."
"*sigh* Sir, there is no such thing as a 12V coil."
"But, there must be. My car is 12V and it has been running fine until the coil blew. I need a 12V coil."
