Re: Which replacement factory style coil to buy? 6 or 12 Vol
Posted by Mike1972chev on March 08, 2012 at 06:42:42 from (75.149.81.173):
In Reply to: Re: Which replacement factory style coil to buy? 6 or 12 Vol posted by DC Snider on March 08, 2012 at 06:11:22:
The ones I am seeing DC Snider have a separate part # for each the 6 and 12 volt. SO,I am thinking they both have a different resistance internally???
I guess If I could call someone knowledgeable who sells these.they could give me the technical data on each???
Or,I could buy either and just check it with an Ohm meter and add ballast accordingly???
Anyone know the ACTUSALL resistance of these new IH looking/ style replacement coils????
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
