Re: Hauling a couple of M's
Posted by Andrew Z on March 08, 2012 at 09:37:21 from (72.10.122.33):
In Reply to: Hauling a couple of M's posted by Darwindo on March 08, 2012 at 09:31:18:
Yes as long as they are not weighted up. Ie 3 sets of weights, loaded tires etc. A bare M comes in at just over 5200 give or take what you have on it. Make sure there all bound tight and have the proper chains on them, follow the speed limit and be safe and you'll be good to go.
Andrew
