Re: Hauling a couple of M's
Posted by rustred on March 08, 2012 at 10:00:52 from (74.200.18.156):
In Reply to: Hauling a couple of M's posted by Darwindo on March 08, 2012 at 09:31:18:
from experience you will be maxed out, weight and trailer room. maybe get away with the occational haul, but for regular trips would look at longer and heavier axles. i have 2-10,000 lb.dually axles and 34ft and am glad i went that way. nice to have some leeway if the bulldogs stop you.
