Re: IH distributor (M) CORRECT stud that passes thru base???
Posted by AG in IN on March 08, 2012 at 11:21:39 from (67.236.118.157):
In Reply to: IH distributor (M) CORRECT stud that passes thru base??? posted by Mike1972chev on March 08, 2012 at 10:28:36:
If you're talking about the electrical terminal stud, IH 353907R1/STP IHS988 is what you want for the IH distributor. I don't know the size/tpi count offhand of the stud.
The inner insulator/anchor is: IH 353906R1/STP IHS974.
The outer insulating washer is: IH 251538R1/STP IHS1294
All parts listed should still be available from CIH.
There are 2 different Delco Remy ignition unit terminal studs available. The stud sizes for these are different. From STP they come with the insulators/nuts/washers as a package. The IH replacement one from STP for some reason does not and the pieces must be purchased seperately.
AG
This post was edited by AG in IN at 12:19:55 03/08/12.
